WCS time settings not correct
Jul 6th, 2007
We have an issue with the time setting in the GUI of the WCS. The box is set with the right time but in the web interface, the time is set 4h in advance.
The controller is also a the right time.
Overall Rating: 5 (1 ratings)
pmccubbin Wed, 07/25/2007 - 12:31
  • Silver, 250 points or more
I'm having the same issue. The time on the box which the WCS is running has the correct time but my WCS software is off by 4 hours.
I don't see any way to configure via the GUI.
Is this a bug?
Thanks in advance.
All responses will be rated.
Rob Huffman Wed, 07/25/2007 - 13:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
I'm not sure if this is the exact issue you are seeing, but I remembered reading this Great answer from Dan Campbell regarding WCS Time;
Make sure in your /etc/sysconfig/clock file the first line looks like:
#ZONE=UTC
Without the # sign in front of this line the server will UTC regardless of how you configured the timezone.
Hope this helps!
Rob
pmccubbin Thu, 07/26/2007 - 06:24
Hi Rob,
Thanks for the reply. I should have mentioned that I am using a Win2003 box to run the WCS software.
I believe Dan Campbell's answer applies to a Linux or Unix box as I couldn't find the directory he mentioned in Win2003.
Paul
pmccubbin Tue, 07/31/2007 - 07:54
We fixed the issue by setting the time via the CLI on each controller.
We had been seeing an incorrect time on the Controllers when we were monitoring them through the WCS.
It appears you cannot set the timezone when you create a NTP template on the WCS. If I am mistaken someone please correct me.
Thanks in advance.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
