Line protocol on access ports are going up and down
Answered Question
Jul 6th, 2007
A number of our 3560s are indicating ports that are going up and down. These connections are connected to printers or pcs. Here is a copy of the show log statement:
618975: Jul 6 11:22:12.352: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/22, changed state to up
618976: Jul 6 11:22:12.394: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/12, changed state to up
618977: Jul 6 11:22:12.520: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/5, changed state to up
618978: Jul 6 11:22:14.424: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/28, changed state to down
618979: Jul 6 11:22:16.429: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/28, changed state to up
618980: Jul 6 11:22:41.654: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
618981: Jul 6 11:22:43.658: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
618982: Jul 6 11:22:48.457: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/10, changed state to down
618983: Jul 6 11:22:50.462: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
tEthernet0/10, changed state to up
618984: Jul 6 11:23:12.750: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
618985: Jul 6 11:23:14.764: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fas
And a Show interface on a port haivng the same problem:
FastEthernet0/20 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.e7df.2d16 (bia 0019.e7df.2d16)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1000 bits/sec, 2 packets/sec
660327 packets input, 132595868 bytes, 0 no buffer
Received 15372 broadcasts (0 multicasts)
139 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 45 multicast, 0 pause input
9714405 packets output, 1165338432 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Anybody know why this would happen? It is happening on different switches.
Correct Answer by xcz504d1114 about 10 years 2 weeks ago
More than likely cabling issues, bad end terminations, not proper clearance from things such as flourescent bulbs causing line interference, bug or rodents chewing the line, length of the cable.
Could be alot of reasons but more than likely it is a cabling issue, I see alot of linkflap errors in my buildings that have fiber to the PC due to bad cabling all the time. Most of the time for cat5 cable it will be bad end terminations or cable length.
Keep in mind cable length should not exceed 100 meters (300 feet) and to maintain proper twist on the connectors as well as make sure the cable ends touch the tip of the RJ-45 and the cable sheath should be secured by the crimp. Don't forget to check your punch downs also.
Craig
Overall Rating: 5 (1 ratings)
Correct Answer
xcz504d1114 Fri, 07/06/2007 - 08:34
  • Bronze, 100 points or more
Craig
Edison Ortiz Fri, 07/06/2007 - 08:37
  • Hall of Fame,
    Founding Member
It seems like you are forcing the speed/duplex to 100/FD on the switchports while the workstations are running auto/auto. This will produce a duplex mismatch. Please change the switchport to speed auto and duplex auto and let us know if that worked out.
faze1sari Fri, 07/06/2007 - 08:54
Speed on the ports is always set to auto on both sides. I'm guessing it might be the run from the closet to the wall jack or (crossing my fingers) the run from the switch to the jack in the closet...we do get a bad set of patch cables from time to time. Thanks for your help at least we know its not the switch that is in error, will forward this to the telecom people.
