ACS IP pools per Client assignment ?
Jul 6th, 2007
I have three locations with 3 remote access servers, users are being authenticated against TCACS on ACS 3.3.
There is an option to have local IP pools on RAS servers with different IP scopes and same name and have ACS
assign this pool name to each location. It is doable
Is it possible though to have three different pools on ACS itself and assign IP from specific pool in dependance of
which cocation/Client request came from?
Alex
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Fri, 07/06/2007 - 07:46
  • Red, 2250 points or more
Alex,
Uunfortunately the ACS cannot assign addresses from different pools based on the device (NAS) the request is coming from. It can however assign addresses from different pools if the
users are members of different user groups on the ACS.
The best solution to this issue would be to continue to authenticate the user on the ACS and assign the IP addresses from local pools on RSA.
Please rate if that helps !
~JG
