Jon Marshall Fri, 07/06/2007 - 08:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Well you could do
192.168.6.40 0.0.0.7
host 192.168.40.49
although this is dependant on how 192.168.6.0 -> 39 hsa been subnetted (if indeed it has ).
Jon
dgahm Fri, 07/06/2007 - 11:10
  • Blue, 1500 points or more
Sparky,
Here is the last octet binary for your range of numbers.
00101000 40
00101001 41
00101010 42
00101011 43
00101100 44
00101101 45
00101110 46
00101111 47
00110000 48
00110001 49
Note that only the 128, 64, and 32 bit value positions do not change, and are always 001 (32). If you use a mask of 0.0.0.31 to "don't care" the changing bits, you get a range of 32-63 for your summary. So a single summarization exceeds your range.
If you move two more bits right with the must match position (00101 or 40) the remaining 3 "don't care" bits mask 0.0.0.7 give you a range of 40-47. This is closer, but you still need 48 and 49.
The 48-49 range can be matched with a 0.0.0.1 mask.
So, 2 statements are required:
192.168.6.48 0.0.0.1
Please rate helpful posts.
Dave
Jon Marshall Fri, 07/06/2007 - 11:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Dave
Thanks for catching that. My mistake with the .48 address.
Deserves rating
Jon
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Dave
Apologies to sparky.
Deserves rating - only it won't let me rate it. Any ideas why - does Sparky have to rate it first ?
Jon
dgahm Fri, 07/06/2007 - 13:11
Jon,
Fortunately perfection is not a requirement for posting on NetPro -- if it was, none of us would be here.
Strange on the rating, never had a problem with it.
Dave
Jon Marshall Fri, 07/06/2007 - 22:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dave
Thanks for this. I stil can't rate this post which i don't understand so i have rated your multicast post in IP telephony which worked !!
Jon
