Remote Access VPN to Site-to-Site VPN
Jul 6th, 2007
We have a remote access VPN and a site-to-site VPN. Both work fine except that clients of the remote access VPN can not access hosts on the site-to-site VPN.
We are 10.5.5.0
Site-to-Site VPN goes to 10.2.2.0
Remote access clients can access anything on 10.5.5.0 but nothing on 10.2.2.0.
What needs to be done to allow this to happen?
acomiskey Fri, 07/06/2007 - 09:04
Is this ASA/PIX 7?
You need to add the traffic between the lans to the nat exemption and crypto acls on the firewalls.
Headend Firewall
same-security-traffic permit intra-interface
access-list extended permit ip 10.2.2.0 255.255.255.0
Remote Firewall
Also, if you are split tunnelling you need to add the remote subnet to be tunneled.
Please rate helpful posts.
pmolaughlin Fri, 07/06/2007 - 09:18
BTW, realized I was using the wrong account.
Thank you!
PIX 506E (6.3) is local, PIX 515E (7.0) is remote.
I am getting "Command failed" when I attempt to execute:
Thoughts?
pmolaughlin Fri, 07/06/2007 - 09:33
Is there another option besides using two different remote access VPNs for each client?
acomiskey Fri, 07/06/2007 - 09:42
Not that I know of. The problem is version 6 will not let you u turn traffic out the same interface it arrived on. It would work if the version 7 was headend and version 6 was at remote site.
acomiskey Fri, 07/06/2007 - 11:20
The PIX 501, PIX 506/506E, and PIX 520 security appliances are not supported in software Version 7.0.
Jon Marshall Fri, 07/06/2007 - 09:44
Do you have a router behind your Pix 506 or is it just a single subnet behind the pix ?
Jon
