"detach crypto map attached to interface"
Jul 6th, 2007
I'm about to set up easy hardware VPN client on my asa 5505.
Received 2 errors. I corrected the first.
Second error is to VPN Client enabled -"detach crypto map attached to interface outside"
I'm using the asdm. Do I need to use command line to remove this entry? or can i use asdm? What directory in the asdm would it be generally under. I cannot find anything.
Thanks bros.
