Ground for ISR 2811
Jul 6th, 2007
Have purchased a new ISR 2811. The 'Cisco Regulatory Compliance and Safety Information' pamphlet states that the ISR should be grounded during operation.
WOuld I be taking a risk if I configured the ISR 2811 without the ground in place? I do not have the ISR connected to my WAN or LAN and will not while configuring the device.
Any thoughts on my doing the config without a ground in place?
Thank you,
mgconghaile
Richard Burts Fri, 07/06/2007 - 12:59
mgconghaile
Perhaps I am not understanding something about your post but whether or not you have your WAN or LAN connected does not seem to have any impact on whether your router has a ground or not. In my experience many people install and operate routers like the 2800 series without installing the earth ground that is described.
Rick
royalblues Fri, 07/06/2007 - 21:35
mgconghaile
Mostly the rack you use to mount your devices would by itslef be grounded and in this case a seperate grouding would not be necessary for the device.
Narayan
