H.323 Plar to AA configuration, need help
Jul 6th, 2007
Gateway: Cisco 2811 with newest IOS
CallManager: Ver 5.1
Unity Connection: Ver 1.2
CAll FLOW:
All incoming calls would be going to Unity AA first. During business-hour calls will be transfered directly from the AA to the receptionist, if receptionist is not available, a Working-Hour-AA will handle the call. As soon as it hits 5:00PM then it will not go to the receptionist but will play the After-Hour-AA call handler. I have the connection plar working to the AA.
The configuration works well during business-hour.
Problem:
After-Hour-AA will allow caller dial the extension, so I need the configuration:
dtmf-relay h245-alphanumeric
on the VoIP dial-peer.
When I tested to dail the main number(main number-> gateway-> plar 500[AA Number]), I hear the Unity prompt "I cannot recognize this invalid entry" instead of the After-Houre-AA, but the caller can still dial an extension and the call can be established successfully.
If I remove the configuration:
from VoIP dial-peer, the call can be transfered to After-Hour-AA, but Unity cannot receive the extension caller dialed(it is true).
Related Configuration:
controller T1 0/0/1
framing sf
linecode b8zs
ds0-group 0 timeslots 1-2 type e&m-wink-start
ds0-group 1 timeslots 3-24 type e&m-wink-start
interface GigabitEthernet0/1
ip address 192.168.70.2 255.255.255.0
duplex full
speed auto
media-type rj45
no keepalive
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.70.2
voice-port 0/0/1:0
connection plar 500
voice-port 0/0/1:1
connection plar 500
dial-peer voice 100 voip
preference 1
destination-pattern 500
session target ipv4:192.168.70.10
incoming called-number 9.T
codec g711ulaw bytes 80
no vad
dial-peer voice 1 pots
destination-pattern 9.T
direct-inward-dial
port 0/0/1:0
dial-peer voice 2 pots
direct-inward-dial
port 0/0/1:1
