excessive icmp rouind trip time
Jul 6th, 2007
For year and half 5510 operates just fine, then it has abruptly slowed by a factor of 10. When on the line the ping times are in the 400 ms range, when off or very lightly loaded in the 18 ms range. DSL provider has changed equip and lines but same thing. running a 9K packet count with nearly 500 dropped. The 5510 is at the main office and 7 501s connect to it over various broadband technologies, regardless of distance still get (at times 450 ms) long round trip times only when 5510 is on line.
amritpatek Thu, 07/12/2007 - 16:34
The response time reporter feature allows you to monitor network performance, network resources, and applications by measuring response times and availability. With this feature you can perform troubleshooting, problem notifications, and preproblem analysis using response time reporter statistics as a baseline.
The response time reporter feature is currently available only with the IBM feature set of the Cisco IOS software. A CiscoWorksBlue network management application will be available to support the response time reporter feature. Both the CiscoWorks Blue network management application and the router use the Cisco Round Trip Time Monitor (RTTMON) MIB
