ASA 5505 webVPN (SSL) client
i have a Cisco asa5505 firewall running code 7.2. I uploaded the file (sslclient-win- into the disk0 without any problems, but when i issue "svc image disk0:/sslclient-win-" i get an error message saying... ERROR: Not a valid SVC image - extraction failed. what am i missing? Is that not the right file/image?
JORGE RODRIGUEZ Sat, 07/07/2007 - 18:46
assuming you have the tftp server running with this image try once more.
asa5500# copy tftp flash
Address or name of remote host []? ip of tftp
Source filename []? sslclient-win-
Destination filename []? sslclient-win-
Fernando_Meza Sun, 07/08/2007 - 03:16
Hi .. What you are doing is correct. It is most likely a corrupted image. For testing the image .. type the following command. If the image is OK, you should receive a similar output otherwise you might received an ERROR message which indicates the file is probably corrupted in which case I suggest downloading it again from Cisco
ASA505# show webvpn svc
1. disk0:/sslclient-win- 1
CISCO STC win2k+ 1.0.0
Mon 12/11/2006 18:41:54.43
1 SSL VPN Client(s) installed
