Copy tftp problems with sub-interface
Answered Question
Jul 6th, 2007
I have a 2811 router at a remote location. The router's Ethernet port has 3 subinterfaces, - the main interface is unnumbered but 0/0.1, 0/0.2 and 0/0.3 are numbered and are using dot1q encapsulation. If I do a ping command I have to do the extended ping and choose what interface I want to use. That has been working for me but now I need to copy the config to a ftp server but it is not working. I believe it is similar to the ping problem because it doesn't know what interface to use but I can't specify what interface to use in a copy command. Am I overlooking something really simple? The VLAN 1 interface is tagged as native. Thanks.
Correct Answer by Jon Marshall about 9 years 9 months ago
Just to be clear, are you talking about tftp or ftp because you mention ftp in your message.
Assuming tftp try this command
ip tftp source-interface "interface"
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 07/06/2007 - 13:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
bretcollins Fri, 07/06/2007 - 13:06
Yes I meant tftp. That is what I needed - thanks for the quick reply, it's already working.
Jon Marshall Fri, 07/06/2007 - 13:07
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Glad to have helped
