VPN Not Working
royalblues Sat, 07/07/2007 - 04:35
Are the tunnel destination reachable from both ends? i do not see any routes except for one static route to tunnel
can you post sh ip route
Can you also add the transform set under the crypto profile
crypto ipsec profile VTI
set transform-set ali
Narayan
royalblues Sat, 07/07/2007 - 08:19
Ali,
How are routerA and router B connected?
with the information you provided, routerA does not seem to have a route for the tunnel destination and hence the tunnel is not coming up. The VPN will come up only when your tunnel is up
Narayan
sundar.palaniappan Sat, 07/07/2007 - 08:38
Ali,
Add static route to the tunnel destination address on both routers. You should be able to ping the GRE tunnel IP address of each other. IPSEC SA should come up after that.
Sundar
sundar.palaniappan Sat, 07/07/2007 - 09:31
Ali,
The static route(s) you have is for the LAN at the far end but you need a static route to get to the tunnel destination address itself. Can you add the following static routes on both routers. This would cause the tunnel int to come up and you should be able to ping the tunnel IP of each other router.
Router-A:
ip route 193.1.1.1 255.255.255.255 (next-hop-address)
Router-B:
ip route 192.1.1.1 255.255.255.255 (next-hop-address)
Sundar
sundar.palaniappan Sat, 07/07/2007 - 09:35
I just noticed you posted that these are routers are directly connected to each other via serial int. If they are directly connected to each other the serial interface of both routers need to be on the same subnet. Can you reconfigure it that way.
royalblues Sat, 07/07/2007 - 09:40
Ali,
The serial interfaces are connected together but yet in o yur configuration they lie in a seperate subnet
on router B configure
interface Serial1/2
ip address 192.1.1.2 255.255.255.0
interface Tunnel0
tunnel source 192.1.1.2
tunnel destination 192.1.1.1
On router A
nterface Tunnel0
tunnel source 192.1.1.1
tunnel destination 192.1.1.2
and also set the transform set under the crypto profile
have a look at this for an example configuration
http://www.cisco.com/en/US/products/ps6635/products_white_paper0900aecd8029d629.shtml
HTH, rate if it does
Narayan
royalblues Sat, 07/07/2007 - 10:07
this generally means the devices are not configured with the same properties.
Make sure the profile parameters are similar in both the peers otherwise negotiations will fail
Narayan
Jon Marshall Sat, 07/07/2007 - 10:07
Hi Ali
For Cisco error message doc
%CRYPTO-6-IKMP_MODE_FAILURE : Processing of [chars] mode failed with peer at [IP_address]
Explanation Negotiation with the remote peer has failed.
Recommended Action If this situation persists, contact the remote peer.
You may see this even if you successfully negotiate a tunnel. Could you post full debug when tunnel is failing.
Jon
Hello!
Router-A#show crypto session detail
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, X - IKE Extended Authentication
M - Continuous Channel Mode
Interface: Tunnel0
Session status: UP-ACTIVE
Peer: 192.1.1.2 port 500 fvrf: (none) ivrf: (none)
Phase1_id: 192.1.1.2
Desc: (none)
IKE SA: local 192.1.1.1/500 remote 192.1.1.2/500 Active
Capabilities:(none) connid:1 lifetime:23:50:07
IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 0 drop 0 life (KB/Sec) 4413422/3010
Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 4413422/3010
Gateway of last resort is not set
C 192.1.1.0/24 is directly connected, Serial1/1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
S 192.168.2.0/24 is directly connected, Tunnel0
C 192.168.3.0/24 is directly connected, Tunnel0
Router-A#
Router-A#s
FastEthernet0/0 192.168.1.1 YES manual up up
Serial1/0 unassigned YES unset administratively down down
Serial1/1 192.1.1.1 YES manual up up
Serial1/2 unassigned YES unset administratively down down
Serial1/3 unassigned YES unset administratively down down
Tunnel0 192.168.3.1 YES manual up up
Router-A#sh crypto isa
Router-A#sh crypto isakmp sa
dst src state conn-id slot status
192.1.1.2 192.1.1.1 QM_IDLE 1 0 ACTIVE
