ACS 1113 recovery issue
Jul 7th, 2007
First time when I boot the ACS 1113 and access through serial port , whenever i put login promp Administrator
not getting any password promt for last 40 mnt only cusor blinking.
Try to recover through CD that also not performing for last two hrs.
Kindly provide solution.
Premdeep Banga Sat, 07/07/2007 - 08:55
Its either device is bad or you are trying to recovery with a bad media.
Try to get new media for ACS SE 1113 (Recovery CD)
If still issue exists, go for an RMA.
I am considering that this is a new box that you are trying to configure.
wmblake755 Mon, 07/09/2007 - 11:38
be sure you have your serial console settings set right for the ACS, IIRC they are different than the standard cisco stuff.
