Wireless controller issues
Jul 7th, 2007
I have just deployed a 4402 wireless controller and updated autonomous 1231 aironets to lightweight mode. All works ok.
I create an interface on a vlan and added IP addresses etc.
Whenever i attempt to associate a WLAN with the interface the only interface available is Management
Another problem is if I create a interface and dont enable Dynamic AP management I loose access to the controller and have to remove the interface via the service port.
Any ideas would be welcome
ericgarnel Mon, 07/09/2007 - 10:11
On the WLC, is the newly created interface enabled?
You should enable dynamic ap management on the management interface or other interface, not a dynamically created interface for client traffic.
Is the port from the switch to WLC in trunk mode?
jwadleigh Fri, 08/24/2007 - 10:44
Confirm the following:
1.) Management and AP-Manager interface are on a single VLAN.
2.) Dynamic Interface is on a different VLAN and enabled.
3.) Both VLAN's exist on the connected switch.
4.) The connected switch port is configured as a dot1q trunk including both VLAN's listed above.
