Inexperienced user, 877W setup
Jul 7th, 2007
I have been trying to get this router setup properly for a few days now, and realised that not knowing IOS is a big disadvantage as SDM is perhaps "flaky".
So far I have managed to get ADSL over POTS by sending over "ppp pap sent-username [email protected] password xxxxxxx"
But the connection was unstable, being able to load a few sites at first and then loading none (DNS cache?).
My question is, what additional commands would I need to send over, and one for WLAN activation with a WPA-PSK key would be appreciated as well.
I'm going to take a stab at your connection problem. Have you configured mtu sizes? When utilizing PPPoE, the header size grows, and when the payload of a packet is large enough, the full size of the packet is larger than what can be transmitted.
To adjust this, set the following:
dialer interface - ip mtu 1492
LAN interface - ip tcp adjust-mss 1452
(the LAN interface could be bvi1, vlan1)
Good luck.
-Jeff
slayerhawk Fri, 03/14/2008 - 13:13
I have the following config.
My users are behind a Catalyst 1900.
They cannot connect to 12 websites.
I tried using the ip tcp adjust-mss command on the FA0 interface, but it would not take the command.
Any suggestions?
