PIX 7.X & 6.3 --- TCP 443 vs TCP 444
Jul 7th, 2007
Hi All,
We have a webserver hosted on DMZ.
A Static PAT on port 443 results in intermittent connection (Internet explorer displays Page cant be display immediately and sometimes works fine) while a STATIC Port redirection from 444 port makes the webserver work fine.
The Static PAT below looks something like this.
Works fine => static (DMZ,outside) tcp 213.X.X.X 444 10.153.122.55 https netmask 255.255.255.255 0
Doesn?t work properly. Intermittent drops => static (DMZ,outside) tcp 213.X.X.X https 10.153.122.55 https netmask 255.255.255.255 0
My question is what is it that PIX does for TCP 443 and not for TCP 444? Is there a way to stop the SYN protection on PIX ?
The packet capture on PIX/Client/Server shows that the client is sending a RST when PIX is listening on 443. Client completes the TCP handshake properly if PIX is listening on 444. I have tried changing MTU, changing TCP timeouts, adding ?norandomseq? to the static . Anything I?m missing ?
All FIXUP/Inspections have been truned off. The configuration for 443 and 444 are exactly same.
If I change my firewall frm PIX to Microsoft ISA, it works absolutely fine. So I know PIX is the culprit here.
I have a TAC open for this but nothing much happening from there.
JBDanford2002 Sat, 07/07/2007 - 16:40
Is there any other device using 213.X.X.X as an IP address? Can you post a scrubbed config?
swapnendum Sun, 07/08/2007 - 00:34
there i nothing much in the config...a STATIC PAT and ACL on OUTSIDE...here is the current config....i have tried removing all fixups, disabling floodguard..setting MTU, setting MSS..norandomseq.....the configs have been reverted back to default as of now...
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
no fixup protocol dns
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
no fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list ACL_OUTSIDE permit tcp any host 213.X.X.X eq https log
access-list ACL_OUTSIDE permit tcp any host 213.X.X.X eq 3389 log
access-list ACL_OUTSIDE deny ip any any log
pager lines 24
logging on
logging monitor debugging
logging buffered debugging
mtu outside 1500
mtu inside 1500
ip address outside X.X.X.X 255.255.255.0
ip address inside 10.153.122.56 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
static (inside,outside) tcp 213.X.X.X 3389 10.153.122.55 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp 213.X.X.X www 10.153.122.55 www netmask 255.255.255.255 0 0
static (inside,outside) tcp 213.X.X.X https 10.153.122.55 https netmask 255.255.255.255 0 0 norandomseq
access-group ACL_OUTSIDE in interface outside
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 60
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
: end
JBDanford2002 Sun, 07/08/2007 - 03:46
Are you port forwarding the IP address that is assigned to your outside interface?
swapnendum Mon, 07/09/2007 - 06:26
Yes.
During my current test YES since i didnt have any free public IP. I have made sure that the internal http server of PIX is disabled so tht there is no conflict.
I have tried it without using the Outside IP as well , also Static NAT has been tried instead of static PAT. All these resulting in intermittent connectivity to the webserver.
any comments ?
