HTTP Compression
Jul 7th, 2007
We had comfigured http compression with ssl termination.
In compression statistics
I am getting :
Compression Statistics:
HTTP Responses In: 122,852
Compressed HTTP Responses Out: 15,191
Bypassed HTTP Responses Out: 107,661
HTTP Response Bytes In: 698,443,874
Compressed HTTP Response Bytes Out: 77,628,963
Bypassed HTTP Response Bytes Out: 418,560,407
Compression Ratio Percentage: 73%
# of connections closed/reset due to:
Unknown Method: 0
Pipelined Data: 0
Client Tag Format: 0
Server Tag Format: 0
Internal Error: 0
# of files bypassed due to:
Method: 24,838 Status: 4,918
Client Version: 33,406 Server Version: 0
Accept-Encoding: 0 MD5 or Encoded: 0
File Extension: 34,746 Content Type: 59
C-Bypass Total: 92,990 S-Bypass Total: 14,783
Data Too Small: 9,806
Most of http response are bypassed through compression algorithm.
What parameter needs to be configured to reduce bypass?
Configured parameter are as follows
Compression Type: ASCII
Compression Encode: Auto
Compression Accept-omit: Gzip
Compression TCP settings:
Virtual TCP Inactivity TO: 240 Server TCP Inactivity TO: 240
Virtual TCP Syn Timeout: 30 Server TCP Syn Timeout: 30
Virtual TCP Ack Delay: 200 Server TCP Ack Delay: 200
Virtual TCP Fin Timeout: 30 Server TCP Fin Timeout: 30
Virtual Min Retrans Timer: 500 Server Min Retrans Timer: 500
Virtual TCP Nagle Algorithm: enable Server TCP Nagle Algorithm: enable
TCP Receive Buffer: 32768 Server TCP Queue Delay: 750
TCP Transmit Buffer: 65536
Thanks in Advance
Aniruddha
