Jumbo frames
san-pandey
Hi, is it possible to change the mtu to 1600 bytes on cisco routers and switches. Although the interface is 10/100/1000BT, the interface is configured at 100M full duplex? What is the maximum byte size that you can configure on a 10/100BT interface.
San
vishwancc
Level 3
Level 3
yes san its possible,depending on the OS you are using.
Check this link
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
thanks. Now I have to find out what series will be used between the two end points.
San
