Catalyst 35xx Link Flaps with Intel PRO 1000 NIC & HP DC 7700 Desktops
Jul 8th, 2007
Hi All,
I am getting numerous link-flaps from a current batch of HP DC7700's which have the Intel NIC Onboard 82566DM Gigabit NIC's using the latest drivers. The system are Intel Core 2 Duo's with VPRO AMT.
If I plug the PC's into a Linksys WRT54G they do not link-flap. Connection is rock solid reliable.
If I force the system to use this driver I have no link flaps:-
e1e5132.sys = Version 9.2.24 Date 2nd Dec 2005 the system does not appear to link-flap.
Drivers that I have testest which link-flap:-
e1e5132.sys = Version 9.5.12 Date 26th July 2006
e1e5132.sys = Version 9.4.21 Date 20th July 2006
Anything later than this driver listed above; the system's link-flap. I have seen a high number of link-flaps per minute.
Cisco IOS I have tried:-
12.0.5-WC17(ED)
12.0.5-WC16(ED)
12.0.5-WC15(ED)
12.0.5-WC11(ED)
I have reset the startup-config's to default.
I have run out of Ideas. I would like to know why this is happening as I prefer not to use a Older driver. This seems like a band-aid to me.
Thanks all.
a.cruea1980 Mon, 07/09/2007 - 08:17
Shot in the dark, but have you perhaps tried a different batch of DC 7700's?
Have you loaded up the newest driver on one DC7700, and one of the older drivers and compared the two, see if Intel dropped in something new?
Also, have you tried sniffing the traffic coming off the computer? Could well be just a bad driver sending crap frames or packets out.
Oh, and you don't have multiple allowed VLANs assigned to those ports, do you?
daboss100 Mon, 07/09/2007 - 16:45
Yes I have tried several DC7700's and they all do the same. The older driver is rock solid reliable keeps a connection fine.
Have not sniffed the network. Will dot his next.
One big VLAN so its not that.
Thanks for your help.
daboss100 Mon, 07/09/2007 - 16:47
locking port settings on both switch and desktop do not help.
FastEthernet0/7 is up, line protocol is up
Hardware is Fast Ethernet, address is 0006.2877.e4c7 (bia 0006.2877.e4c7)
Description:
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Auto-duplex (Full), Auto Speed (100), 100BaseTX/FX
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 2000 bits/sec, 2 packets/sec
1868434 packets input, 840441615 bytes
Received 6759 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 5039 multicast
3611544 packets output, 4042912323 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
show diags link-flaps
FastEthernet0/7 171 0
daboss100 Mon, 07/09/2007 - 18:30
Vista drivers also link-flap
e1e6032.sys = Version 9.8.20.0 Date 13th April 2007
daboss100 Wed, 07/11/2007 - 17:55
Hi All,
I have done a packet capture and nothing is causing the link to flap. I see no network traffic before the link-flap.
Any other help would be greatly appreciated.
daboss100 Wed, 07/18/2007 - 17:43
Hi All,
I have done some extensive testing & the WS-C3524-XL-EN overheats when these NIC's are connected to the switch causing link-flaps. 2 IC's on the board get very hot.
WS-C3548-XL-EN have a different cooling system compared to the 3524's which have 4 little fans.
I dont know if it is a design fault or just that my switch has weak fans due to age.
