SSH on ASA 5510
Jul 8th, 2007
Hi Everybody,
I configure SSH on my ASA5510 which looks like ssh 10.0.0.0 255.255.255.0 inside, version 1 and 2 & ssh timeout 5 is not working, but the same config i used in router, core switch is working fine. I do need to configure any more to work ssh on my asa ?, PLZ suggest
Thanks in advance
jgervia_2 Wed, 07/11/2007 - 03:47
also check your netmask - unless you're on the 10.0.0.0/24 network, you should make that netmask 255.0.0.0.
--Jason
Please rate this message if it helped solve some/all of your issue or question.
