Routers' Serial WAN Interfaces
Jul 8th, 2007
Can somebody please clarify to me the difference between the following modules:
1-WIC-2T: 2-Port Serial WAN Interface Card
2- WIC-2A/S: 2-Port Async/Sync Serial WAN Interface Card
Also, if I need 16-port serial module, do I need to order: HWIC-16A?
One last question: what does this module do: NM-32A?
Haitham
amit_kulshrestha_2 Sun, 07/08/2007 - 21:47
2 port serial WIC (WIC-2A/S or WIC-2T)
- The only difference between the WIC-2A/S and the WIC-2T is the maximum
supported sync speed.
- Aysnc support with a max speed of 115.2 Kbps, minimum 600 bps (use the aux
port for lower speeds).
- WIC-2A/S Sync support with a max speed of 128 Kbps.
- WIC-2T Sync support with a max speed of 2.048 Mbps.
Yes,you need to have HWIC-16A in order to have 16-port Serial Module.
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd80274416.html
For your last question click url below:-
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800a93f0.shtml
