Please Product No. for E1 ATM Module IMA
husseinmuneer
I bought cisco router 2811 and I need E1 ATM Module card with IMA .
I got this prod. #
(( 4ports E1 ATM network Module with IMA ))
but it is supported on routers:
2600
3600
3700
3800
I need the exact Product No. for the same card which will be compatible with cisco 2811 .
Thank you for your help ..
paolo bevilacqua
For the new ISR routers, you do ATM IMA using VWIC cards and the AIM-ATM internal module. There is also a kit that contains both items, but I'm not sure if it is available as spare. Anyway the P/Ns are:
VWIC-xMFT-E1 (x = 1 or 2 ports)
or (either with will work)
VWIC2-xMFT-T1/E1 (x = 1 or 2 ports)
and
AIM-ATM
AIM-ATM-1E1 is the package that can implement IMA but has only on E1 port.
If you go for AIM-ATM-4E1 u got 4 e1 ports.
Cheers!
Dear p.bevilacqua ,
I bought the same card which you mentioned but now I have another problem .
The problem is that the IOS doesn't support that module so I installed it then I made sh run but I didn't see it .
The IOS which I have is :
IP Base
c2811-ipbase-mz
So if I have :
Advanced Enterprise Services
c2811-adventerprisek9-mz
or
Advanced IP Services
c2811-advipservicesk9-mz
Maybe the problem will be fixed but how can I get the IOS image because the resaller doesn't have it .
