Richard Burts Sun, 07/08/2007 - 17:30
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Edgar
The IOS does not have any specific limit on the number of secondary addresses that can be configured. You can configure as many secondary addresses as it makes sense to use.
Is there a particular situation in which you need many secondary addresses? If we knew what your requirements were we might be able to give you better advice.
Rick
