Ip Servce Image for 3560 switch that are used for L3/L2
Amit Singh Mon, 07/09/2007 - 00:32
  • Cisco Employee,
No, it doesnot depend on the IP services image. Ip services only provides the following capabilties:
Dynamic Routing Protocols:
-Open Shortest Path First (OSPF)
?Enhanced IGRP (EIGRP)
?Border Gateway Protocol Version 4 (BGPv4)
Policy-based Routing (PBR)
?Allows superior control by enabling flow redirection regardless of the routing protocol configured
Protocol-Independent Multicast (PIM)
?For IP multicast routing within a network that enables the network to receive the multicast feed requested and for switches not participating in the multicast to be pruned-support for PIM sparse mode (PIM-SM), PIM dense mode (PIM-DM), and PIM sparse-dense mode
Distance Vector Multicast Routing Protocol (DVMRP)
?Tunneling for interconnecting two multicast-enabled networks across non-multicast networks
Private VLAN (PVLAN)
?Provides the ability to restrict communications between hosts at layer 2 through the use of primary and secondary VLANs.
It actually depends on the IDB limit on the IOS.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml#max_no_vlans
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_qanda_item09186a00801b0971.shtml
HTH,Please rate if it does.
-amit singh
