07-09-2007 12:06 AM - edited 03-05-2019 05:11 PM
Dear All,
I have a 2610 router that is running OSPF and ISIS, I want to connect the router to an SDH NE (Alcatel) which is not running IP. However it has an NSAP address. Is there any special configuration on the router's interface connected to the NE?
I've already configured the interface to suppport clns. Below is the configuration that i made on the router.
Clns routing
Router isis
net 39.682F.8000.0000.0000.0001.0003.3333.3333.3333.00
is-type level-1-2
!interface FastEthernet0/0
ip address 10.190.17.90 255.255.255.248
ip router isis
duplex auto
speed auto
clns router isis
isis circuit-type level-1
interface Serial0/1
ip address 10.190.30.6 255.255.255.252
ip router isis
clockrate 64000
clns router isis
isis circuit-type level-2-only
I tried to ping the node using ping clns 39.682F.8000.0000.0000.0001.0003.0020.6001.4314.1D but it failed, however when I ping the neighbor router (3725) it was connecting so i assume that isis is ok between the two routers.
I think I am missing something...
Can anybody help me out.
07-09-2007 06:09 AM
I'm not sure and this is just a guess, but have you tried adding "clns enable" to the interface facing the Alcatel system?
07-09-2007 10:32 PM
tnx for your reply. I've already done that and it was not working. so, I removed it. Its really odd coz when i tried to view the neighbors(show clns neighbors) the system id of the NE is actually displayed and its state is up. However when i tried to ping (ping clns XX.XXXX....XX) the NE's NSAP address, it was not reachable. Below are some show commands that Ive done on the router.
AREA3ECCM#sh clns neig
System Id Interface SNPA State Holdtime Type Protocol
Area1MAIN Se0/1 *HDLC* Up 23 L2 IS-IS
0020.6001.4314 Fa0/0 0020.6001.4314 Up 163 IS ES-IS
AREA3ECCM#sh isis route
IS-IS Level-1 Routing Table - version 97
System Id Next-Hop Interface SNPA Metric State
0020.6001.4314 0020.6001.4314 Fa0/0 0020.6001.4314 10 Up
AREA3ECCM --
AREA3ECCM#sh clns protocol
IS-IS Router:
System Id: 3333.3333.3333.00 IS-Type: level-1-2
Manual area address(es):
39.682f.8000.0000.0000.0001.0003
Routing for area address(es):
Interfaces supported by IS-IS:
FastEthernet0/0 - OSI - IP
Serial0/0 - OSI - IP
Serial0/1 - OSI - IP
Note: The Alcatel NE is connected via Fa0/0
interface.
07-10-2007 08:44 AM
The only thing I can suggest is to remove all the ISIS configuration from the F0/0 interface and add the "clns enable" and then try it. Below is the explanation:
"clns enable" - You also must enable ISO CLNS for each interface you want to pass ISO CLNS packet traffic to end systems, but for which you do not want to perform any dynamic routing on the interface.
Unfortunately that's probably the best I can offer. Also, just in case you don't have this, I've attached a CLNS config PDF.
