asa 2 interfaces with 1 ip address
Jul 9th, 2007
i have 2 asa running active/passive connected to a 2 core switch running hsrp.
i need to have 2 coonections on both the asa's. one going to the core1 and another going to core2.
question. Is it possible to have 2 asa interfaces to have single ip address?
thanks
a.shaukat Mon, 07/09/2007 - 03:05
if you are talking abt 2 interfaces on A single ASA then that cant be done ..
but 2 ASA's can have same IP address conencted to 2 Core switches.. i was still getting the grasp of Failover scenarios with active active failove ul have to set up multiple contexts in the asa .. then you can give 2 different contexts a same ip address..
try to find Active/Active failover example on cisco... Document ID: 91336
plz rate if it helps.. :-)
