Is a Cisco Flash Memory necessary on router 2821(can I use another brand)
Answered Question
Jul 9th, 2007
Is a Cisco Flash Memory necessary on router 2821 (can I use another brand)
The cost of the Cisco Flash Memory 128MB is about 5 times the cost of a non Cisco one.
I find it hard to pay, especially since Cisco does not produce them.
Has anybody every tried another brand with success ?
Thank you very much.
Gregory Gout
Correct Answer by paolo bevilacqua about 9 years 11 months ago
Hi Gregory,
Any good brand will work. The thing is that is hard to find the small sizes used on routers, and I'm not 100% sure a bigger size would work.
USB memory is less of a problem and I've used 1GB sticks from different vendors without any problem.
Hope this helps, please rate post if it does
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Mon, 07/09/2007 - 01:34
  • Hall of Fame,
    Founding Member
Hi Gregory,
