MRTG - Implementation Help Required
Jul 9th, 2007
Hello All,
I need to implement MRTG in our customer premesis with all features.
Pls help me in MRTG implementation & Configuration. If possible can anyone provide me the Complete Configuration file of MRTG(with all features included), so that i can modify the same as per my requirement.
Thanks & Regards,
Guru Prasad R
a.shaukat Mon, 07/09/2007 - 02:47
you can try PRTG from paessler softwares to begin with ... :-) nice n easy to install..
use snmp community and ul be on ur way ..
btw its GUI based.
guruprasadr Wed, 07/11/2007 - 21:00
HI Amit,
Link provided by you is not opening. Pls Help
Best Regards,
Guru Prasad R
