7911 - Unkown Numbers - CME4.1
Jul 9th, 2007
When checking the list of calls made from a 7911G phones, all the numbers appear as uknown. The received and lost calls information is correct though. What might be wrong at the cme configuration?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 07/09/2007 - 03:33
  • Hall of Fame,
    Founding Member
Which IOS are you running? This bug is fixed in 12.4(11)XJ3.
abartolomeu Mon, 07/09/2007 - 05:48
The IOS is c2800nm-ipvoicek9-mz.124-11.XJ.bin. I'll upgrade it.
abartolomeu Mon, 07/09/2007 - 06:10
