fan assy for a 3725
Jul 9th, 2007
We have a bad fan assy for a 3725 router. I'm in the process of ordering a replacement for it however I can only find the one for the 3745 router or CISCO3745FANASSY=
Does anyone know if this is interchangeable in the 3725?
TIA
Brian
Anonymous (not verified) Fri, 07/13/2007 - 10:43
There is no part number for the fan in a 3725 chassis. If the fan has gone out it will be necessary to replace the whole chassis.
magnaroute Thu, 12/16/2010 - 04:49
If the router is not under SMARTnet, there are companies selling fan replacement kits for the 3725.  Search google and you will find them.
