Microsoft Network Load Balancing
Jul 9th, 2007
Hello. I need help.
I have a cluster running windows 2003 server which are in a Catalyst 3560G and belong to VLAN named "servers".The Network Load Balancing cluster hosts are connected to the Ethernet switch (3560G)
which is connected to a centralized Ethernet Routing Switch (Catalyst 4510R)using a single uplink port
trunk. Clients are connected to Catalyst 4510R directly and others layer 2 swichtes Catalyst. I want to deploy Microsoft Network Load Balancing using mode Multicast. How can I do it?. What configuration have I to do in the switches (Catalyst 4510R and 3560G)?.
lactogal2 Mon, 08/20/2007 - 06:57
hello Bryan, it's possible to setup MS NLB whith C2960 and C2970 cisco switch's
