net flow with vrf
Jul 9th, 2007
i use 2 vrfs. i configured net flow, and it sent but i didn't recieve. i used the same configuration on other router without vrfs - worked fine.
is there another command to use net flow with vrfs? i have C3845-IPBASEK9-M.
swaroop.potdar Mon, 07/09/2007 - 05:50
  • Blue, 1500 points or more
AFAIK, you will need MPLS Aware Netflow (Netflow V9) supported by your IOS and the switching platform. I believe this support is there in IOS 12.4T.
These links would be handy in configuring the same.
MPLS-Aware Netflow
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e1147.html
MPLS Egress Netflow
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00805e1253.html
HTH-Cheers,
Swaroop
blacktulip Tue, 07/10/2007 - 05:32
according to the feature navigator, MPLS-Aware Netflow doesn't work with 3845, no matter which image i use.
can it be?
do i have some other option?
swaroop.potdar Tue, 07/10/2007 - 06:54
I checked the FN, as it doesnt show up the 3845 for the MPLS Aware Netflow.
Although it does support Netflow V9 export, which will export couple of new data sets including MPLS.
But I believe on the 3845 the MPLS accounting is not there yet, so even if it supports exporting that data, there is no capability to account for it in the first place.
Its a good idea to check with your local account SE regarding any roadmap of the feature for your platform.
HTH-Cheers,
Swaroop
