Amit Singh Mon, 07/09/2007 - 07:13
  • Cisco Employee,
If you want to have HSRP for your routers, you have to have 1 interface on each router with one ip address in the same range and configure the multiple groups under that with the Virtual IP configured in the same range. You can also create secondry ip addresses and create the HSRP group for standby addresses.
Forexample :
Router 1:
ip address 192.168.2.1 255.255.255.0 secondary
standby 1 ip 192.168.1.100
standby 2 ip 192.168.2.100
Router 2:
ip address 192.168.2.2 255.255.255.0
ip address 192.168.1.2 255.255.255.0 secondary
The following link should help you in understanding it more clearly.
http://www.cisco.com/en/US/tech/tk1330/technologies_design_guide_chapter09186a008066670b.html
HTH,Please rate if it does.
-amit singh
