CSS Compression
Answered Question
Jul 9th, 2007
Hello All,
I've the following scenario:
Box-to-Box implementation and SSL Termination, on 2 CSS 11501S-C, with SW Version 08.10.1.06.
What i need is compress the "Java" data type of all data on the content "Tst.Aplj".
Correct me if im wrong :
As i could understand, the compression is made by a file extensions, and content types. (Cisco Content Services Switch SSL Configuration Guide, Page 9-2)
What should be better for me, if i want to compress Java when it passthrough the CSS.
Could u give me a example, please.
I have the following configuration:
****** SERVICE ******
service MODSSL
slot 2
type ssl-accel
keepalive type none
add ssl-proxy-list ssl1
active
service esl0008
ip address 10.1.1.190
keepalive type http
keepalive uri "/"
keepalive port 80
active
service esl0019
ip address 10.1.1.174
keepalive type http
keepalive uri "/"
keepalive port 80
active
****** OWNER ******
content SSL-Tst.Aplj
vip address 10.1.2.134
add service MODSSL
application ssl
advanced-balance ssl
protocol tcp
port 443
url "/*"
redundancy-l4-stateless
active
content Tst.Aplj
protocol tcp
port 80
add service esl0019
add service esl0008
active
Best Regards,
Bruno Petr?nio
Compression is enabled in a service -- compress enable -- that covers all the default types of traffic that is subect to compression as documented. If a service with compression is in a content rule that gets hit, then compression will be attempted. You can have multiple services with the same ip with one not using compression while the other one does.
If you want to fine-tune what gets compressed, then you would use a L5 rule with something like a eql (extension qualifier list). If you only want to compress Javascript, then your eql would contain "js". If you organize all your JS in a directory of the root of the web server (like we do) called /java, then you can just use a L5 rule that uses 'url "/java/*" to match instead of the eql. JS is an excellent candidate for compression.
Overall Rating: 5 (1 ratings)
b.petronio Tue, 07/10/2007 - 00:16
Could any one give me an example of compression on file extensions ?
Best Regards,
Petr?nio
Correct Answer
b.petronio Wed, 07/18/2007 - 02:26
Many Thanks for ur very excelent contribut for my knoledge.
Best Regards,
Bruno Petr??nio
