07-09-2007 09:21 AM - edited 03-14-2019 10:27 PM
I would like to know is there a script or an easy way to lets say I have a User with a 7960 and they have all 99 speed dials configured, they also have Fast Dials configured under services.
The user now is going to be upgraded to 7961G-GE, how do you move all the speed dials and appropriate fast dials to that new phone?
CCM 4.1(3)sr4d.
Thanks in advance
07-09-2007 10:57 AM
That info is stored in the directory.
No matter which phone you use, this will depend on the user configured for the services.
So you only need to subscribe the services for this new phone and login with the previous user.
07-09-2007 11:44 AM
So the speed dials for the device are in the dir, how would you get them to a new device but same user?
The services I knew but I always double check just to make sure.
Thanks!!
