monitor dial access - usernames and ip's
Jul 9th, 2007
I have aaa auth and snmp / syslog running on my Cisco3640 for dial in users. The users are authenticaticated against a Win2k box and the resulting connection info is sent to my syslog/snmp server.
The problem is the info is not very good. It basically only shows if the port has come up and when it goes down again ( i.e. Async 85 up ). I would like the syslog / snmp server to show the username and if possible the assigned dhcp address for all dial in users.
Is this possible ?
I have looked under snmp-server traps and accounting and cant seem to see the correct command set.
Any thoughts ?
cheers
Richard
sadbulali Fri, 07/13/2007 - 13:57
  • Bronze, 100 points or more
I think you will have to configure syslog at level 4 or 5 for logging the messages for users logging in through dial up. Following links may help you
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a00800a7275.shtml#topic1
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00801a9564.html
