Rob Huffman Mon, 07/09/2007 - 10:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bob,
Dual RG-6 coaxial cable to run from the power injector to the 1300. See attached notes:
Cisco Aironet 1300 Series Access Point/Bridge Power Injector
The Cisco Aironet 1300 Series Outdoor Access Point/Bridge Power Injector,converts the standard 10/100 BaseT Ethernet interface that is suitable for weather protected areas to a dual F-Type connector interface for coax cables that are more suitable for harsh outdoor environments. The Power Injector also provides power to the outdoor unit over the same cables with a power discover feature and surge protection. To support longer cable runs from your wireless network switch or router, the Power Injector LR is designed to accommodate up to a 100 meter coaxial cable run plus 100 meters of indoor cat5 cable enabling total cable runs up to 200 meters. The Cisco Aironet 1300 Series Outdoor Access Point/Bridge ships with the Power Injector LR2 and an AC power supply.
From this link:
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022551d.html
Cisco Aironet 1300 Series Outdoor Access Point/Bridge Hardware Installation Guide
Ethernet Ports
The access point/bridge dual-coax Ethernet ports consists of a pair of 75-ohm F-type connectors, linking the unit to your 100BASE-T Ethernet LAN through the power injector. The dual-coax cables are used to send and receive Ethernet data and to supply inline 48-VDC power from the power injector to the access point/bridge.
Power
The access point/bridge receives inline power from the Cisco Aironet Power Injector (hereafter called the power injector). Dual-coax cables are used to provide Ethernet data and power from the power injector to the access point/bridge. The power injector is an external unit designed for operation in a sheltered environment, such as inside a building or vehicle. The power injector also functions as an Ethernet repeater by connecting to a Category 5 LAN backbone and using the dual-coax cable interface to the access point/bridge.
From this link:
http://www.cisco.com/en/US/products/ps5861/products_installation_guide_book09186a00804d3095.html
AIR-PWRINJ-BLR2
F-Type Connectors
Dual coaxial cable carries full-duplex Ethernet, DC power, and full-duplex console port (RS-232 connection)
From this link:
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a00802252e1.html
Here are the specs:
Dual RG-6 Coax 0.041 inch (1.05 mm) center conductor diameter
From this doc;
http://www.cisco.com/en/US/products/hw/cable/ps801/products_installation_guide_chapter09186a008007e013.html#xtocid149761
Hope this helps!
Rob
sethgarnar Mon, 07/09/2007 - 10:54
You need RG6 coax cable for 1300's. We use Belden 1694A type cable for our installs.
