DMZ and Inside problems with NAT
Answered Question
Jul 9th, 2007
Hi all,
I have a ASA5510 with outside public IP, DMZ public network (x.x.x.64/29) and inside private (192.168.2.0/24) and I want to give access from the outside to the inside using an IP address from the DMZ.
The idea is to have a www.test.com pointing to x.x.x.65 (it's not the IP of the interface) but I don't have a server in the DMZ, I only have a server inside (192.168.2.10).
How can I do this?
Best regards for all.
Correct Answer by acomiskey about 10 years 2 weeks ago
Does this work...
static (inside,outside) x.x.x.65 192.168.2.10 netmask 255.255.255.255
access-list outside_access_in extended permit tcp any host x.x.x.65 eq www
access-group outside_access_in in interface outside
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Mon, 07/09/2007 - 10:07
  • Green, 3000 points or more
Does this work...
rcordeiro Mon, 07/09/2007 - 10:27
My config:
interface Ethernet0/0
nameif Inside
security-level 100
ip address 192.168.2.2 255.255.255.0
interface Ethernet0/1
nameif DMZ
security-level 50
ip address x.x.x.70 255.255.255.248
interface Ethernet0/2
nameif Outside
security-level 0
ip address 192.168.10.2 255.255.255.0
access-list Outside_nat0_inbound extended permit ip any x.x.x.64 255.255.255.248
access-list Outside_access_in extended permit ip any host x.x.x.69
access-list DMZ_access_in extended permit ip host x.x.x.69 host 192.168.2.15
nat (Outside) 0 access-list Outside_nat0_inbound outside
static (Inside,DMZ) x.x.x.69 192.168.2.15 netmask 255.255.255.255
access-group Inside_access_in in interface Inside
access-group DMZ_access_in in interface DMZ
access-group Outside_access_in in interface Outside
This is the relevant config.
acomiskey Mon, 07/09/2007 - 11:14
Did you try my posted suggestion above?
