Unity 4.0.3 How to disable system prompts or change the language
I am running Unity 4.0.3, the system was originally installed in US English only and now that the system is expanded to our Chinese users in China. I would like to find out if there is a way to disable the system prompts or change the prompts to chinese. For exmaple like when I call a Chinese user I get their mailbox greeting in Chinese but after the greeting the prompts are in English (you may record your message after the tone .....)
Any ideas ?
thank you very much !!!
Danny
navinger Thu, 07/12/2007 - 20:59
  • Bronze, 100 points or more
