PIX 501 User license changed after applying high encryption activation key
Jul 9th, 2007
Had a PIX 501 with 10 user lic. Applied 50 user lic. a long time ago. Recently went and downloaded 3DES encryption activation key and system has now reverted to 10 user. Is there anything I can do to get my user lic. back?
vitripat Mon, 07/09/2007 - 12:32
  • Gold, 750 points or more
If your PIX was running with 50 user license earlier, and if you have a "show version" from that license, please mail it to [email protected] along with current show version output. They will be able to send you the activation-key with 50 users + 3DES license. Even if you don't have the old show version, but you did receive the 50 user license key, you should still contact [email protected] about the issue you faced after getting 3DES key online, they'll be able to checkup their database and send you the correct license with both 50 users and 3DES.
Hope this helps.
Vibhor.
