ASDM 6.0 not working after upgrade
i just upgraded my asa5520 to verion 8.2 and my asdm to version 6.0, but now when i open asdm and click on my configuration tab i don't see anything on the page. The only tab that seems to work is the home tab i'm able to see all the charts (vpn tunnel, device info, traffic status..etc) i rebooted the firewall and restarted my workstation.
Thanks for any info...
smalkeric Fri, 07/13/2007 - 13:52
  • Silver, 250 points or more
If you want to use ASDM instead of the CLI to configure the security appliance and you have a factory default configuration, you can connect to the default management address by pointing your browser to https://192.168.1.1. Alternatively, you can use the Cisco ASDM Launcher (if it is already installed) to connect to ASDM. For more information, see http://www.cisco.com/en/US/products/ps6121/products_user_guide_chapter09186a008081027e.html#wp1237308
