Question about message filters
Jul 9th, 2007
I've a question about the message filter. Is it possible to use
alt-mailhost() in combination with $RemoteIP? I have to send some outgoing mails to the ironport appliance for virus checks, and then send them back to the sending mailserver. I know that it sounds stupid, but I must do it really in such a way...
Any ideas?
Axel
verylongbloke_i... Tue, 07/10/2007 - 13:27
One way would be to:
1. create a msg filter that adds the source ip address as an x-header via CLI command 'filters->new'
ADD-SOURCE-IP:
if (true)
insert-header('X-ip', '$RemoteIP');
Then commit filter.
2. Use a content filter to look for X-header value to then to use altmailhost to send back to the correct MTA.
Hope this helps...
asteiner_ironport Tue, 07/10/2007 - 15:10
I already thought somtething like this. But how can I use the header value in the contentfilter gui!? I can't use variables in the "Send to alternate destination host" action.
xame_ironport Thu, 07/12/2007 - 08:05
Have you got a lot of MTA?
Because you can create one rule by MTA...
Example:
In message filter:
verylongbloke sayed how do that...
and in content filter:
rule1: if (header("X-IP") == "^1.1.1.1$") { alt-mailhost ("[1.1.1.1]"); }
rule1: if (header("X-IP") == "^1.1.1.2$") { alt-mailhost ("[1.1.1.2]"); }
It's not very sexy but it works fine...
unfortunately, we can't use variable for alt-mailhost action... or I don't know how :)
regards..
asteiner_ironport Thu, 07/12/2007 - 10:12
Thats not a solution for me :-(
I've about 600 MTAs to manage, and the IPs can change. It's no problem for me, to store the IPs in a LDAP directory.
I need a solution that either alt-mailhost allows variables or that I'm able to route the mails via LDAP with the 'From' address as search key.
