Router Set-up and Configuration
paulgrg22
I'm a newbie to cisco my problem is on how to set-up a cisco router 1700 series how could i configure it using the console and do i used rollover RJ-45?any help regarding this?because i set-up my small internet connection using my router and modem
15 Replies 15
royalblues
Level 10
Level 10
all you have to do is configure IP addresses on the interfaces and a defualt route
eg. your inside LAN connects to Fa0/0
int fa 0/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
no shut
int fa 0/1
description connecting to internet
ip adddress
ip nat outside
no shut
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
ip nat pool internet interface fastethernet 0/1 overload
ip nat inside source list 100 pool internet
Narayan
how could i do this in the router how could i connect my router to pc so that i can configure it??what is Fa0/0?
HI Paul, [Pls rate if Helps]
See below the Link for step-by-step procedure for connecting PC to Router:
http://www-tss.cisco.com/eservice/compass/common/tasks/task_console_port_connect.htm
Pls Rate if HELPS
Best Regards,
Guru Prasad R
what's the next thing i do once i connect it to console how can i configure it
plug the blue cable in the router(rj45-console port) and the other end to your computer (serial port). turn on the router
open hyterterminal program on your connected pc set things to default settings and select com port (1 or 3)
press connect and hit enter a couple of times.. you will see Router> prompt.
type "enable" the prompt will change to Router#
type "show ip interface brief" to see how many interfaces you have on the router.
FastEthernet0/0
FastEthernet0/1
type "config terminal"
prompt will change to Router(config)#
type interface fastEthernet0/0
prompt will change to Router(config-if)#
now type "ip address 192.168.0.1 255.255.255.0"
or any other ip address n subnet mask that you want to give to your router.
once you do that
type exit again exit to come back to the Router# prompt
here type "write"
your configuration will be saved int he router.
now type "show run" and run it.. hit the space bar till it shows the complete information.. ul get the Router# prompt again when its finished..
copy the display that you get after running this command and paste it here (in an attachment
and tell me what you need to do next..
:-) please rate if this helps..
you will see the routers prompt
Thanks it helps me..i can log in now but it prompts davao> instead of Router> i type davao>login and prompt me a username i dont know what is the username what should i do next is??
If you don't know the username and password, you need to perform a password recovery. Please follow this link:
http://www.cisco.com/warp/public/474/pswdrec_2600.shtml
Note.- It mentions 2600 and 2800 routers but it works for your router as well.
HTH,
hi
Can anybody here tell me exactly on how to recover the password for 1750 router???thanks
Almost all the Cisco devices are password recovered in similar way. One may observe the following steps to recover the password / reset the password.
1. Make sure that you are able Console the Router i.e. you have established connectivity through the Consol Port using Hyperterminal and now getting Router Prompts.
2. Reboot the Router, and while its rebooting, issue Ctrl+Break Command (most of the time its just Ctrl key + Break Key simultaneosly and the Router will get to the Rommon Mode with rmmon> prompt
3. At this point, set the Configuration Reg Parameters to 0x2142 by issuing command confreg 0x2142
4. Once the Conf. Reg has been changed, you can reboot the router by simply pressing the i key on the keyboard
5. The Router will reboot and by-pass the Startup-Config file and you will be placed in the Initial Config which you can bypass and
finally copy the startup-config to running-config and then change the password, save the config and reboot the router
6. Now you should be able to logon using the new password.
Hope this helps,
Please rate if it helps
Kind Regards,
Wilson SAmuel
paul...
do these steps exactly and let me know..
when u get the prompt with the ">" sign do this..
davao> enable
now you should get the prompt like this with the "#" sign
davao#
if you can get there then its alright.. if it asks you for a password when u type enable then you need to know the password before you can proceed further..
a.shaukat
i do those steps davao>enable and ask for a password how could i dont know the password what would do next???
paul,
follow the steps wilson described earlier in this post and ul be well on the way ...
if u run into anything again do let us know here :-)
rate all helpful replies..
I follow what wilson said and i have the password now...my ISP give the IP address,subnet mask,DNS and a modem im connecting thru DSL line so how could i configure it so that i can connect to the internet..what should i do to the router???
