Encryption 3DES and DES
Jul 9th, 2007
Recently i was configured my C7206 (IOS 12.4.10a) to remote router C2801 (IOS 12.4.9.T1) with ipsec configured via leased line. All the application are working fine if i configured the encryption using DES. However, when i configured the encrytion using 3DES, all the application still work fine except one of the printing job using DLink print server across this ipsec. Configuration as follows:
crypto isakmp policy 30
encryption 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxxx address
crypto ipsec transform-set Tunnel-Transform-IPSec ah-sha-hmac esp-aes 256 esp-sha-hmac
mode transport
crypto map IPSEC-R1-R2 101 ipsec-isakmp
set peer
set transform-set Tunnel-Transform-IPSec
match address 101
interface Serial0/1
ip address
mtu 1600
bandwidth 1984
encapsulation ppp
crypto ipsec df-bit clear
Any one can help?
pkapoor Wed, 07/11/2007 - 08:59
In global configuration mode, enter the following command and see if it works.
"crypto ipsec df-bit clear"
Then test with 3DES.
