Running H323 and SIP on the same cisco gateway
Jul 9th, 2007
Hi there!
I running Yate and Asterisk/IAX2 in the same box, to get H323 and convert to SIP, but I have a costumer that wants to send H323 with codec g723, but it doesn?t work good at all. So, can have H323 and SIP running on the same box like a c3600 or c2600?
Jonas
Paolo Bevilacqua Tue, 07/10/2007 - 04:05
Yes, absolutely.
Note: if you want to show your customer something nice, show the PBX features of CME.
teodorgeorgiev Tue, 07/10/2007 - 04:19
I may go out of topic, but:
1. If you want reliable protocol (H323<-> SIP) and codec conversation and
2. If you wanto to show your cusotomer nice PBX features,
then go fo either MERA MVTS or Alterteks PSS softswitches.
Paolo Bevilacqua Tue, 07/10/2007 - 04:37
Do the products you mentioned a nice PBX for 30 users, 1 RU rugged unit without disk, hundreds of well documented features for voice, thousand of features for data integrated in the same box, for approx 1500 USD ?
