Cisco Works Netconfig
Jul 9th, 2007
Netconfig configured with a Task to deploy Access-list config out to Routers and Switches to 190 devices returns a fail to 35 of the 190 devices. The Failure message is detailed below. Applying the config manually to the device works.
Failure message : Command(s) failed on the device TFTP: Failed on the device. Insufficient no. of interactive responses(or timeout) for command: access-list 1 remark ?SNMP Read-Only Hosts?.
David Stanford Tue, 07/10/2007 - 07:33
  • Cisco Employee,
How are you doing carriage returns in your interactive commands?
Can you select one of the failing devices and attempt the job again while performing a packet capture?
You can also turn on debugs for netconfig.
