Forward Port Range with one Public IP.
Jul 9th, 2007
Hi Everybody:
What is the way to forward a port range to internal ip address and don't break the router internet access?
My situation:
I've a SHDSL connection with 878 (IOS version 12.4) and one public IP.
If I configure:
"ip nat inside source static <private ip> <public ip> route-map VOIP extendable" to do a port range forwarding, the router lost the internet access.
What is the correct way?
Thanks and best regards,
olafmarcos Tue, 07/17/2007 - 11:23
I thought any router does, but in practice, cisco routers need at least 2 public ip addresses for doing. Don't you think is a waste of public ip addresses?
Do you have a working config?
