Excessive collision
Jul 9th, 2007
Guys.. are there any way to deal with excessive collision?
I typed show interface eth 0 and i got so many collisions and deferred frames.and I typed show controller eth 0 and i got so many excessive collisions and multiple collisions..
Jon Marshall Tue, 07/10/2007 - 00:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
if you run in half duplex you will get collisions anyway, there is nothing you can do about it.
If you are seeing lots of late collisions that suggests that one end of the link thinks it has a different speed/duplex than the other end of link.
If both of your interfaces are capable of full duplex then hardcode both to full duplex at either 10 or 100.
Alternatively you could set both to auto but auto-negotiation does not always work.
Jon
Suwandy.Ong Wed, 07/11/2007 - 18:05
so, it's just a matter of duplexing, then? If i change it to full-duplexing, then it'll be alright?
Thanks for the kind reply...
patrickvanham Thu, 07/12/2007 - 12:18
If the interface that is showing collisions is a basic ethernet (as suggested by th designation eth0) you'd probably need to set up the other end as speed 10 and duplex half, as a basic ethernet isn't capable of more.
