service policy & CEF
Answered Question
Jul 10th, 2007
Is it mandatory to have CEF enabled for proper functioning of policy-map applied on interface..
How & why ?
regards,
Gaurav
Correct Answer by a.shaik about 10 years 2 weeks ago
Hi Gaurav,
Please see this excellent document which explains why CEF is required.
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a0080094978.shtml
Hope this helps you
regards
Shaik ASSANA
Overall Rating: 5 (1 ratings)
mohammedmahmoud Tue, 07/10/2007 - 02:49
  • Green, 3000 points or more
The link provided by Shaik ASSANA is very useful, in brief many useful class-based QoS features are supported only on routers that run CEF, ex: NBAR, CB-Marking, ..., and accordingly if you reqiure these features you'll need to run CEF.
HTH,
Mohammed Mahmoud.
vinay_verma80 Tue, 07/10/2007 - 04:04
we use CEF because policy map is like access-list , and we have to transfer at wired rate
if we do in software it will slow down the router as it has to match very large no of packets
use command in global config mode
ip cef ( this is enable by default on all new router which support cef)
