IOS SSLVPN 12.4(15)T Bookmark
Jul 10th, 2007
Anyone able to insert bookmarks and display Web links on SSLVPN portal?
It seems like the 12.4(15)T Early Deployment cannot display Web links. It works fine on 12.4(9)T codes.
roy-sam Sun, 07/15/2007 - 19:59
I have done some testing and adding personal bookmark somehow block from a particular laptop. It works fine on another laptop.
I discovered that when user add personal bookmark, the user bookmark is stored as XML file in the flash. I am still trying to figure out how to create permanent bookmark for all users.
Directory of flash:/webvpn/SSLVPN_PROFILE/
3 -rw- 257 Jul 16 2007 02:00:46 +00:00 user.xml
31916032 bytes total (2379776 bytes free)
C1841#more user.xml
<?xml version="1.0"?>
roy-sam Wed, 08/08/2007 - 00:50
I have managed to resolve the issue. I am running on ISR 1841 12.4(15)T1 ADV SECURITY image.
It seems that whenever I enable the following command "mask-urls" under the policy group, the Pre-configured bookmarks links disappeared.
policy group SSLVPN
mask-urls <--- "conflict with pre-conf bookmarks"
